IDI AMIN
So the car has just hit 150 000 miles recently but has had no recent work done on the rings.
Only new chains and clean the valves of carbon was the only work i have carried out on engine since i had the car. I should have put new piston rings on when i had the cylinder head off and changed the shells . but my knowledge was limited and was really learning as i went along and also money i had spare at the time
I am doing 100 miles a day and using a lot of oil my rocker cover gasket was leaking badly i got a new one but still seems to be using much oil. is it a wise time to do the pistonrings would that help. im sure it is a factor
Basically need some recommendations for piston rings seen a couple on e bay what brand to avoid etc
http://www.ebay.co.uk/itm/Vauxhall-...+Type:2.2+16V|Model:Astra&hash=item3f150b38d1
http://www.ebay.co.uk/itm/Vauxhall-...140122125356&rk=2&rkt=6&sd=270895524303&rt=nc
http://www.ebay.co.uk/itm/VAUXHALL-...arts_Vehicles_CarParts_SM&hash=item5893638bb4
Should i also change main bearings never done them either
If the head is off again may do a little smoothing work in the ports but nothing crazy. just looking for a little advice .should i also think about new valves
1. new piston rings
2. new main bearings /maybe big end bearings as well
3 .new head gasket set
4. new conrod bolts
Anything else i should add to my list would be good to know and any other work i should do while working on piston rings
1. new piston rings
4. new conrod bolts
