2.4 vvt with a few tweaks
So this engine started life in a Vauxhall Antara, which ended up in the breakers and the engine on ebay :)
VVT head is extremely heavy :confused:
So best thing to do is remove it :D
It is having an external trigger wheel and a Saab head, then a SC :cool:
2mm overhang into the cylinder with the 86mm head ?
does this one have the same crank your using in your vx engine ?
the cylinder head needed some machining, so a quick skim, valves cleaned up and refaced, plus the valve seats were recut
added some brand new valve stem seals and new Saab valve springs
checked the z22yh plastic cam cover for fit
still waiting for the head bolts to arrive, then just need to refit the timing chain and oil pump, etc
genuine head bolts arrived today, so fitted those and finished the build :)
Brand new genuine cam sprockets, sprocket bolts and upper chain guide - 2.4 stuff is totally different (n)
